[Gdal-dev] Link to NTF info?
Ben Discoe ben at vterrain.org
Sat Sep 24 16:08:55 EDT 2005
On the page:
	http://www.gdal.org/ogr/drv_ntf.html
the link "General UK NTF Information" points to:
	http://gdal.velocet.ca/projects/ntf/index.html
Which doesn't seem to be there.
I'm reading elevation grids from NTF using OGR.  It is a bit strange to use
OGR for rasters, but OGR is the one with NTF support.  It works great but i
am wondering if the elevation inside an NTF is always integer or not.  OGR
returns all values as doubles, but in the NTF files i've seen, the values
are always whole numbers.
Thanks,
Ben
