[Gdal-dev] Save a map from a OGRDataSource
Josepo Urrutia find_all at hotmail.com
Tue Sep 27 10:52:17 EDT 2005
I want to program a topographical map editor using the GDAL/ORG library, I
create a OGRDataSource with the ORGLayers and OGRFeatures that represent the
map.
The problem is that I haven't been able to found a way to save this
OGRDataSource into a topographical map on disk.
Which is the proper way to save a map with GDAL/OGR ?
I'm using GDAL/OGR 1.3.0 on a RHEL 4 system.
