[Gdal-dev] Access window out of range
Tue Sep 27 14:41:45 EDT 2005
On 9/27/05, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> > What resampling kernel are you using?
> I do not know. I am not familiar with the resampling kernel, how would
> I determine what I am using?
Rich,
By default you would be using nearest neighbour.  The "-rb", "-rn", and "-rc"
switches control resampling kernel.
>  I am working strictly with TIFFs. And the
> error does seem dependent on cell size. For example: I can patch a 1
> foot/pixel image into a 1 meter/pixel image without error. However if
> I use gdal_translate to convert the destination image from 1
> meter/pixel to 1 foot/pixel, then it fails.
> > What version of GDAL?
> Primarily 1.3.0.0b1 from FWTools 0.9.9. I also did a bit of testing
> with GDAL 1.25 with same errors. Just installed FWTools 1.0.0a1, same
> errors.
OK, that is very current.
> > If it still happens there, then I would appreciate a bug report with data to
> > demonstrate.
> I'll work on that, unfortunately the imagery is quite large so I would
> like to isolate it a little on my end if possible.
Sounds good.
Best regards,
