[Gdal-dev] How does one remove Overviews?
Fri Sep 30 12:41:00 EDT 2005
On 9/30/05, Mike Logan <mlogan at mail.arc.nasa.gov> wrote:
> This has come up a couple times for me..
> I generated overviews in my files for OSG's  osgdem software and
>  didn't like the results due to the black border bleeding into the
>  final imagery.
> Is there a program to remove the overviews and just leave the
>  original data (in a geotiff)?
Mike,
There is no mechanism available to remove overviews from an image.
However, you can just "gdal_translate" the file to a new file and the
new file should be similar to the original but not have the overviews.
Best regards,
