[Gdal-dev] How does one remove Overviews?
Marco Vieira marco_vieira at uk2.net
Fri Sep 30 15:31:07 EDT 2005
> However, you can just "gdal_translate" the file to a new file and the
> new file should be similar to the original but not have the overviews.
I use a little variance of Homme Zwaagstra's gdalsplit.cpp that use
AddSimpleSource method to copy RasterBand and split file after I created
overviews with gdaladdo command. How can I know if my overviews are
preserved?
Marco Vieira.
Fone:    + 55 21 9499-6800
