[Gdal-dev] How does one remove Overviews?
Fri Sep 30 15:46:27 EDT 2005
On 9/30/05, Marco Vieira <marco_vieira at uk2.net> wrote:
> > However, you can just "gdal_translate" the file to a new file and the
> > new file should be similar to the original but not have the overviews.
> I use a little variance of Homme Zwaagstra's gdalsplit.cpp that use
> AddSimpleSource method to copy RasterBand and split file after I created
> overviews with gdaladdo command. How can I know if my overviews are
> preserved?
Marco,
Run gdalinfo on the resulting file, and if it has overviews they will
be reported.  I don't see how they could be preserved though unless
you are doing some deep voodoo.
Best regards,
