[Gdal-dev] Python C API version mismatch
Sean Gillies sgillies at frii.com
Tue Apr 4 16:16:06 EDT 2006
John,
Set a PYTHON environment variable before you configure
   $ PYTHON=/data1/contrib/bin/python2.4 ./configure
Used to get me all the time.
Sean
On Apr 4, 2006, at 1:59 PM, John Cartwright wrote:
> Thanks Sean, that helps.  Seems like my underlying problem is that
> configure is picking up the first python executable in my path (the
> older 2.2.3).  I don't see a way to specify the python executable
> to use, do you know a better solution other than mainipulating my
> environment for the configure/build process?
> -- john
> Sean Gillies wrote:
>> On Apr 4, 2006, at 9:09 AM, John Cartwright wrote:
>>> Hello All,
>>> Can someone tell me what I might have done wrong in compiling
>>> gdal  1.3.1 on linux? I get the following error upon importing
>>> the gdal  module:
>>> /data1/contrib/lib/python2.4/gdal.py:191: RuntimeWarning: Python
>>> C  API version mismatch for module _gdal: This Python has API
>>> version  1012, module _gdal has version1011.
>>> I'm using python2.4.2, and these are my configure options:
>>> ./configure --prefix=/data1/contrib/gdal-1.3.1 \
>>> --with-png=internal \
>>> --with-libtiff=internal --with-geotiff=internal \
>>> --with-libz=internal --with-jpeg=internal --with-gif=internal \
>>> --with-pg=/usr/bin/pg_config \
>>> --with-mysql=/usr/bin/mysql_config \
>>> --with-oci=/usr/lib/oracle/10.2.0.1/client \
>>> --with-geos=/data1/contrib/geos-2.2.1/bin/geos-config \
>>> --with-pymoddir=/data1/contrib/lib/python2.4
>>> Thanks!
>>> -- john
>> John,
>> Is it possible that your pymoddir is not on your Python path, and
>> that you're importing an older gdal.py?
>> I think your configure should probably have
>>   --with-pymoddir=/data1/contrib/lib/python2.4/site-packages
>> just for the sake of keeping site-packages like gdal in the right
>> place.
>> Sean
