[Gdal-dev] gdal_merge.py
Wed Apr 5 21:30:49 EDT 2006
John Cartwright wrote:
> Hello All,
> I'm trying to merge a set of gifs w/ gdal_merge.py.  The generated gif
> cannot be displayed in a browser "because it contains errors".
> gdalinfo seems to think it's OK:
> Driver: GTiff/GeoTIFF
> Same thing happens w/ the GTiff format. Is there something I'm missing
> here or is this the expected behaviour?
John,
I think the problem is that the output file from the merge is a GeoTIFF
and browsers don't know what to do with it.  If you want a different output
format you would have to use the -of switch to gdal_merge.py, but in any
event I don't think it can output directly to gif since gif can only be
created by copying from another file (it is a "create copy" format).
So just translate your GeoTIFF back to GIF.
Also, I think you will need to rerun the merge with the -pct switch
so that the color table of the first input file will be copied to the
mosaic.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
