[Gdal-dev] Projection issues with OGR/Proj.4.
Fri Apr 7 21:03:31 EDT 2006
Sheykhet, Rostic wrote:
> Frank/Ed,
> Thanks for the replies.  I fixed the projection definition and it works
> fine now.  For the record, I was not using the proj.4 definitions for
> the gdal CSV file, but the stock spatial_ref_sys PostGIS database table.
> The definitions were wrong in the table, so caveat emptor.
Rostic,
Did spatial_ref_sys have EPSG:26799?  If so, using that should resolve
the problem.  I think I need to keep better track of deprecated
coordinate systems, and perhaps consider excluding them from some
products or at least clearly marking them.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
