[Gdal-dev] Spherical Mercator using PROJ.4
ronan.gdal ronan.gdal at laposte.net
Tue Apr 11 18:15:34 EDT 2006
I would like to use Spherical Mercator projection (the earth is a sphere model).
My purpose is to produce raster for other software using Mercator projection Sphere formula : merc = ln( tan ( pi / 4 + L / 2 ) ).
My test have been using POSTGIS, entering following PROJ.4 parameters :
+proj=merc +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +k=1.0 +x_0=0 +y_0=0 +units=m +nodefs.
(a=WGS major axis, b=a (excentricity should be null); I've also tried b=0, +ellips=sphere ... always same result!).
Results looks like to be always Mercator ellipsoid projection formula, never SPHERE formula.
Is there any way to use PROJ.4 sphere formula ?
Thanks.
Ronan
Accédez au courrier électronique de La Poste : www.laposte.net ;
3615 LAPOSTENET (0,34 €/mn) ; tél : 08 92 68 13 50 (0,34€/mn)
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060412/49bc6106/attachment.html
