[Gdal-dev] apps / MinGW
Wed Apr 12 10:47:36 EDT 2006
Radim Blazek wrote:
> I had problems with GRASS raster driver, it is using functions from
> GRASS library not VSI functions.
> I thought to add the code above to gdalinfo.c etc. but if it is problem
> only for GRASS I understand that it is not best.
Radim,
Well, not only it is not best, I don't see that doing it in gdalinfo.c would
even have any useful effect.  If the problem is in the GRASS libraries calls
to fopen() (or open() perhaps?) then that is where the fix would have to be.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
