[Gdal-dev] Merging TIFFs
Wed Apr 12 21:42:37 EDT 2006
Andrew Larcombe wrote:
> Hi all,
> I'm after a quick bit of advice before I start coding. I need to write a
> small app that will take a 4000x4000 pixel striped geotiff at resolution
> x and merge it into a number of larger ~10000x10000 pixel tiled (200px
> tile height & width) geotiffs at resolutions y1...yn where y1...yn < x.
> Both input and output are in the same projection.
> Am I best off using the GDALWarp classes or the
> GDALRasterBand->RasteIO() stuff?
Andrew,
If you don't need reprojection, resampling kernels, and so forth then
sticking with RasterIO() will be faster and easier.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
