[Gdal-dev] .ecw convert for GRASS
Miss Carla Meurk s4112669 at student.uq.edu.au
Sat Apr 15 03:14:00 EDT 2006
GRASS cannot seem to import a .ecw using r.in.gdal
I have installed gdal separately and following the instructions in
README.1st I have entered the code:
carla at ubuntu:~/Desktop/fwtools/FWTools-1.0.0b2/bin_safe$
./gdal_translate ~/MapsofDaintree/se5501.ecw ~/MapsofDaintree/se5501.gdal
only to get the following error messages:
Input file size is 7106, 3990
0...10...20...30.ERROR 1: TryWinRasterIO() failed for blocked scanline 0
of band 2.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
Unfortunately, I have no idea what this error message is trying to tell me.
Importing via GRASS (6.0.1) by: file > Import > Raster map > Multiple
formats using GDAL
Raster file to be imported
"file name.ecw"
Name of resultant raster map
"new file name"
and clicking Run gives:
r.in.gdal input = file name.ecw output = new file name
ERROR 4: file name.ecw not recognised as a supported file format.
Can someone help?  All I want is for se5501.ecw to be recognised by GRASS
I would be very greatful for any help
