[Gdal-dev] pluggins
Howard Butler hobu at iastate.edu
Wed Apr 19 18:45:49 EDT 2006
Carlos,
The latest MS4W <http://www.maptools.org/ms4w/> has the OCI and SDE
(as well as MrSID) plugins already built.  OCI is against 10g and SDE
is against 9.1, IIRC.  You will need the SDKs that match to be able
to use them.
Otherwise, you can download the buildkit at
<http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8.3-msvc71-build-kit.zip>
(Warning 310mb!), go into the GDAL directory and edit nmake.opt to
match your setup, and then do a normal make for gdal.
Howard
At 05:36 PM 4/19/2006, Frank Warmerdam wrote:
>CARLOS GARCIA wrote:
>>Dear Gdal-dev
>>Recently I read about the ogr pluggins for ArcSDE and Oracle spatial format.
>>My question is about how can I compile this pluggins (I thing that I can do
>>that (make the dll's)) and once compiled how can I use?
>Carlos,
>What have you tried so far?  What problems did you encounter?  What platform
>are you on?
>If you have built GDAL/OGR from source before, then adding SDE and Oracle
>support requires editing the nmake.opt and uncommenting the relativent
>items, adjusting paths and so forth.
>This approach is to build-in the support.   If you want to build SDE and
>Oracle support as plugins, the process is substantially more involved.
>Howard Butler has already addressed this issue in his buildkit, so you might
>want to look at that.  Otherwise you might need to fiddle around a bunch.
>I think the Oracle driver has a plugin.bat that you can edit and use to
>build it.  The SDE driver has a "ogr_SDE.dll" target you can use to build
>it.  With the nmakefile you would still need to have fixedup the nmake.opt
>appropriately.
>Basically plugin building is not standardized, so it tends to be a hassle.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | President OSGF, http://osgeo.org
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
