[Gdal-dev] building gdal on solaris
Thu Apr 20 15:33:05 EDT 2006
Peter.Rushforth at statcan.ca wrote:
> Hi,
> Newbie in need of help!
> I could only find a linux and windows binary version, so I
> am trying to build gdal on solaris.
> All I really need is the ogr2ogr utility.  I started the build
> process ok, it ran for a while, but it seems the oci.h file is
> not found, terminating the build process.  Question is, how to
> get this train back on the rails?
Peter,
Try configuring "--without-oci".
It seems configure discovered you had oracle, but at build time it
can't find some required stuff.
If you need oracle then you may need to fiddle include paths in
GDALmake.opt.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
