[Gdal-dev] GDAL ImportfromEPSG Error
Tue Apr 25 15:44:24 EDT 2006
Cho Hyun-Kee wrote:
> Hi!
> This is my first time using GDAL.
> I want to set projection information but when I use ImportfromEPSG()
> function, ogrErr return 6.
> The code is like this,
> #include "include\ogr_spatialref.h"
> void main()
>     OGRSpatialReference CustomCoordinateInform;
>     OGRErr ogrErr;
>     ogrErr = CustomCoordinateInform.importFromEPSG(4001);         //
> ogrErr = 6
> How can get PCS,GCS Inform using ImportfromEPSG() function???
Cho,
OGR error 6 is OGRERR_FAILURE, a rather generic code.
I suspect the EPSG csv files aren't being found.  You might
try setting the GDAL_DATA environment variable to point to the
gdal/data directory or possibly just before calling importFromEPSG(),
call:
  GDALSetConfigOption( "GDAL_DATA", "C:\\gdal\\data" );
(well with the appropriate path of course).
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
