[Gdal-dev] building gdal 1.3.X on freeBSD
Eric S. Theise mataro at cyberwerks.com
Tue Apr 25 19:03:55 EDT 2006
Hi Frank,
> If you are encountering this only in the mysql driver, I would imagine
> the issue is a conflict between mysql include files and c++ stl include
> files with regard to the definition of swap.  I just searched my client
> mysql library and they define swap_variable, but not swap.  Perhaps an
> older version of the mysql client sdk on your system uses swap() instead?
Thanks for the tip... I upgraded my mysql & I'm now operational.
--Eric
