[Gdal-dev] GDAL 1.3.2 Beta 2 Released
William Kyngesburye woklist at kyngchaos.com
Wed Apr 26 14:18:17 EDT 2006
Oh, wait.  It's aclocal.m4 in gdal 1.3.1.  I'll look at that and see
what I can do.
On Apr 26, 2006, at 1:07 PM, William Kyngesburye wrote:
> Libtool config stuff is a bit deep for me also.  Do you have a
> libtool.m4 for GDAL 1.3.1 (I don't see one in the source)?  Or is
> this autoconfig thing for libtool part of what's new with libtool
> for 1.3.2?  I could use an old libtool.m4 as a guide - I think I
> found the lines in there that should be changed, I just want to
> make sure.
> I could also try looking at some other projects to see what they do.
> On Apr 26, 2006, at 12:42 PM, Frank Warmerdam wrote:
>> William,
>> Yikes! Can you submit the patch via bugzilla (the patch should
>> presumably
>> be applied to m4/libtool.m4).  I'm a bit nervous about fiddling
>> with this
>> stuff but I also don't want us in the position of lots of MacOS X
>> build
>> problems till the next version after 1.3.2.
>> This libtool stuff *scares* me.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
