[Gdal-dev] compile netCDF and GDAL
NicoSIG nicolasgabarron at yahoo.fr
Fri Apr 28 05:31:06 EDT 2006
I compiled netcdf-3.6.1 and when I compile GDAL-1.3.1, I have this error
message:
memcpy                              0x198
/home/josephine/UnixTools/mapserver/netcdf/netcdf-3.5.1/lib/libnetcdf.a(var.o)
memcpy                              0x1ac
ncx_putn_double_uchar               0xb88
/home/josephine/UnixTools/mapserver/netcdf/netcdf-3.5.1/lib/libnetcdf.a(attr.o)
ncx_putn_double_uchar               0x22e0
/home/josephine/UnixTools/mapserver/netcdf/netcdf-3.5.1/lib/libnetcdf.a(putget.o)
close                               0x1038
/home/josephine/UnixTools/mapserver/netcdf/netcdf-3.5.1/lib/libnetcdf.a(ncio.o)
close                               0x1178
close                               0x11b4
ld: fatal: relocations remain against allocatable but non-writable sections
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory
`/home/josephine/UnixTools/mapserver/gdal/test/gdal-1.3.1'
make: *** [check-lib] Error 2
what's the problem ?
thanks,
Nico
View this message in context: http://www.nabble.com/compile-netCDF-and-GDAL-t1523465.html#a4137182
Sent from the GDAL - Dev forum at Nabble.com.
