[Gdal-dev] OCI driver: validate
Bart van den Eijnden (OSGIS) bartvde at xs4all.nl
Wed Aug 2 07:00:59 EDT 2006
Hi list,
the OCI driver uses SDO_GEOM.VALIDATE_GEOMETRY to validate geometries.
I just wanted to point out that this function has been deprecated:
"The VALIDATE_GEOMETRY function is deprecated and will not be supported in
future releases of Oracle Spatial. You should use instead the
SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT function."
Best regards,
Bart
