[Gdal-dev] Re: Fwd: gdal swig interface Band.i Updated
Daniele Romagnoli dany.geotools at gmail.com
Sat Aug 5 18:45:11 EDT 2006
On 8/6/06, Charlie Savage <cfis at savagexi.com> wrote:
> Hmm, in theory %apply and OUT do the same thing.  Once again, see:
> http://www.swig.org/Doc1.3/Arguments.html#Arguments_nn5
You are right...
Anyway, I would take the simple approach, which is add this line:
> %include "typemaps.i"
> To gdal.i before line 441 which is:
> %include "Band.i"
> And in fact, I'd probably put it on line 192 (before the #if
> defined(SWIGPYTHON).
> Doing that simplifies the problem.  If it doesn't work, then yes, it
> appears the OUTPUT * parameter is not working for Java in which case go
> back to using apply (and maybe submit a bug to SWIG).
Unfortunately, it doesn't work :(
I'll back to using apply...
However, if you use %apply then you should also clear it after the
> method is defined.
> %apply (int *OUTPUT){int *blockXSize, int *blockYSize}
>    void GetBlockSize(int *blockXSize, int *blockYSize){
>                GDALGetBlockSize(self, blockXSize, blockYSize);
> %clear (int *blockXSize, int *blockYSize)
Ok, Thank you. I will add the final %clear directive.
Its probably not that important in this case, but if there happened to
> be another method with the same 2 output parameters then this typemap
> would be applied again (sometimes you want that, sometimes you don't).
> Charlie
> Thank you very much!
Best Regards,
Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060806/cee4c74d/attachment.html
