[Gdal-dev] SDTS not recognized
Bryan Keith bryan at geomega.com
Thu Aug 10 09:54:34 EDT 2006
Nick,
I don't know if the name makes a difference, but all the SDTS archives
I've seen are named in the format nnnnxxxx.ddf when n is a number is x
is a character.
Testing ogrinfo on an archive I have handy gives these results:
ogrinfo 1109CATD.DDF -al -so
ERROR 4: SDTS Driver doesn't support update.
Had to open data source read-only.
INFO: Open of `1109CATD.DDF'
       using driver `SDTS' successful.
If I try a file that's not the CATD file, then I get this error:
ogrinfo 1109CATS.DDF
FAILURE:
Unable to open datasource `1109CATS.DDF' with the following drivers.
   -> ESRI Shapefile
   -> MapInfo File
   -> UK .NTF
   -> SDTS
Note that the archive I just tested is actually a raster dataset not a
vector dataset, but I'd try ogrinfo with the CATD file if you have it.
Hope that helps.
Bryan
trale at centrum.cz wrote:
> Hello list,
> I am having troubles with reading SDTS vector files. Here is what ogrinfo says (from FWTools):
>  C:\Downloads\MoreSTDS>ogrinfo MATRLE01.DDF
> FAILURE:
> Unable to open datasource `MATRLE01.DDF' with the following drivers.
>   -> ESRI Shapefile
>   -> MapInfo File
>   -> UK .NTF
>   -> SDTS
>   -> TIGER
>   -> S57
> Any help is highly welcome !
> Thanks
> Nick
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
