[Gdal-dev] transform on a shapefile using OGR - image 2 projected coordinates
Hannes Isaak Reuter hannes.reuter at jrc.it
Mon Aug 14 05:19:41 EDT 2006
Hallo everybody,
in the documentation of ogr2ogr i found the switch -transform...
What functionality does that imply , and how to apply that switch.
problem:
shapefile with coordianates in image e.g. LLC is 0,0 and URC is 9800,8600
but need to "transform" (soory old arcinfo command ) that to
projection extent e.g. 450000, 560000
solution:
can do that with arcinfo workstation by converting shape to cover and
applying transform command.. ( even in batch), but want to stay in shp file.
any clue if ogr2ogr supports that ?
I tried several ways/switches but are somehow lost..
Hannes
