[Gdal-dev] AutoLoadDrivers question
Tue Aug 15 10:42:38 EDT 2006
ma jianglin wrote:
> Hi Frank,
>      Thank you for your reply! Yes, I want to know what these external
> plugin drivers are useful for.
>      In function GDALAllRegister(), gdal tries to rember every image
> format dirver. Why we need GDALDriverManage::AutoLoadDrivers() first?
Jianglin Ma,
External plugin drivers are used for three primary reasons:
  o Folks with their own proprietary drivers they don't want introduced
    directly into GDAL.
  o Folks who want to add optional drivers to existing GDAL builds without
    having to rebuild everything.
  o Folks with packaging systems where they want to distribute binaries
    with some optional drivers (such as MrSID, Oracle) that depend on
    external libraries that are either big, or may/maynot be found on the
    target system.
If you are building everything from source for use on your own system there
is no strong need to use plugins.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
