[Gdal-dev] gdalwarp reprojection shift
chalmet at telusplanet.net chalmet at telusplanet.net
Wed Aug 16 17:39:07 EDT 2006
I am at a loss. Not being the most experienced user, I was hoping if somebody
could shed some light at the following issue.
I have some data in tiff format. The data is located in Alberta, Canada. It is
projected in "provincial 10tm" which is a Transverse Mercator projection based
on NAD83 with the following parameters:
- central meridian: 115W
- false easting: 500000
- false northing: 0
- scale factor: 0.9992
I am trying to reproject this data to latlong, using a different datum: NAD27.
I have done this in PCI and in ERmapper, and the resulting tiffs line up
perfectly.
If I do this using gdalwarp, I have a shift of about 70 meters compared to my
reprojected tiles in PCI and ERmapper. I use the following command for gdalwarp:
gdalwarp -s_srs "+proj=tmerc +datum=NAD83 +x_0=500000 +lon_0=-115 +lat_0=0
+k=0.9992" -t_srs "+proj=latlong +datum=NAD27" -rc -tr 0.000035 0.000035
400113.tif 400113_latlong.tif
Does anybody know why this is happening. And more importantly, how could I make
the gdalwarp tiff line up with my other tiffs, meaning avoid the 70m shift?
Thanks for any input.
Wim.
