[Gdal-dev] Re: Fwd: gdal swig interface Band.i Updated
Daniele Romagnoli dany.geotools at gmail.com
Thu Aug 17 10:47:43 EDT 2006
Dear Mr. Warmerdam,
Thank you for the update.
I quote here an useful comment of Mr. Charlie Savage.
Mr. Charlie Savage wrote:
However, if you use %apply then you should also clear it after the
method is defined.
%apply (int *OUTPUT){int *blockXSize, int *blockYSize}
  void GetBlockSize(int *blockXSize, int *blockYSize){
              GDALGetBlockSize(self, blockXSize, blockYSize);
%clear (int *blockXSize, int *blockYSize);
Its probably not that important in this case, but if there happened to
be another method with the same 2 output parameters then this typemap
would be applied again (sometimes you want that, sometimes you don't).
Best regards,
Daniele
On 8/17/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Daniele Romagnoli wrote:
> > Dear Mr Warmerdam,
> > Could you please update the Band.i interface resulting from our
> > discussions (between me, you and Mr. Charlie Savage)?
> > The section which needs to be updated is:
> > instead of the actual version:
> > void GetBlockSize(int *OUTPUT, int *OUTPUT){
> Daniele,
> A night or two ago I noticed things weren't even building with the old
> setup (since the name OUTPUT was used twice I suppose), so I changed it to
> this:
> %apply (int *OUTPUT){int *pnBlockXSize, int *pnBlockYSize}
>    void GetBlockSize(int *pnBlockXSize, int *pnBlockYSize) {
>        GDALGetBlockSize(self, pnBlockXSize, pnBlockYSize);
> Things now at least build, though the test suite does not use this
> method.  I'd appreciate your verifying that this is working.
> I apologize for not dealing with this sooner.  I kind of got lost in
> the exchange between you and Charlie.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGF, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060817/7ffdc8be/attachment.html
