[Gdal-dev] ECW compression - Extremely slow Linux performance
Fri Aug 18 12:38:11 EDT 2006
Andrew Larcombe wrote:
> Hi,
> I'm using gdal_translate to convert a 4000px x 4000px uncompressed 46MB
> tiff to an ECW file.
> On a Windows XP laptop (Pentium M 1.6 GHz, 512MB RAM) using the latest
> fwtools download the process takes about 6 seconds.
> On a RedHat Enterprise 3 powered Quad-3.8Ghz processor with 2GB ram
> using gdal-1.3.1 built from source the process takes ~120 seconds.
> In each case the command used is as follows:
> gdal_translate -of ECW -co "TARGET=90" OSIM_TQ3517_2004-07-07.tif test.ecw
> Does anyone have any thoughts on why their is such a considerable
> difference in speed, and what I can do to remedy the situation?
Andrew,
Have you watched the CPU usage to see if it is 100% on the linux system
when doing the compression?  If not, then I *suspect* some sort of thread
switching latency or something similar.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
