[Gdal-dev] ECW compression - Extremely slow Linux performance
Andrew Larcombe andrew at andrewlarcombe.co.uk
Fri Aug 18 14:04:07 EDT 2006
Frank Warmerdam wrote:
> Andrew Larcombe wrote:
>> Hi,
>> I'm using gdal_translate to convert a 4000px x 4000px uncompressed
>> 46MB tiff to an ECW file.
>> On a Windows XP laptop (Pentium M 1.6 GHz, 512MB RAM) using the latest
>> fwtools download the process takes about 6 seconds.
>> On a RedHat Enterprise 3 powered Quad-3.8Ghz processor with 2GB ram
>> using gdal-1.3.1 built from source the process takes ~120 seconds.
>> In each case the command used is as follows:
>> gdal_translate -of ECW -co "TARGET=90" OSIM_TQ3517_2004-07-07.tif
>> test.ecw
>> Does anyone have any thoughts on why their is such a considerable
>> difference in speed, and what I can do to remedy the situation?
> Andrew,
> Have you watched the CPU usage to see if it is 100% on the linux system
> when doing the compression?  If not, then I *suspect* some sort of thread
> switching latency or something similar.
> Best regards,
Frank, Aaron,
Thanks for the prompt replies:
Aaron - yes, in both instances the disk is local. WinXP is a local
NTFS-formatted filesystem, Linux is ext3 formatted in a (I think) raid 1
configuration. Incidentally tiff -> jpg compression of the same file
takes ~1.5 seconds on the Linux box.
Frank - according to top the CPU usage varies but never gets above 20%.
Does this shed any more light on the issue?
Thanks again,
Andrew
Andrew Larcombe
