[Gdal-dev] OGR functionality.
Tue Aug 22 09:39:56 EDT 2006
Murat BEYHAN wrote:
> Dear Friends;
> I'm using mandrake linux limited edition 2005.
> And I'm MapServer user.
> For the connect MySQL by using ogr I have tried following connection
> <OGRVRTDataSource>
>     <OGRVRTLayer name="aqidata">
> <SrcDataSource>MYSQL:eqinfo,user=root,password=mysql_123,host=localhost,port=3306,tables=deneme</SrcDataSource>
>         <SrcSQL>SELECT ID,Lat,Lon,Mag FROM deneme</SrcSQL>
>         <GeometryType>wkbPoint</GeometryType>
>         <GeometryField encoding="PointFromColumns" x="lat" y="lon"/>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> And I have faced the following
> [root at sakura murat]# ogrinfo /var/www/html/map/agidata.ovf
> ogrinfo: symbol lookup error: ogrinfo: undefined symbol:
> _Z26OGRGeneralCmdLineProcessoriPPPci
Murat,
This problem isn't related to the .ovf file particulars.  It almost
certainly means your ogrinfo executable is using the wrong version of
libgdal.so (likely an older version of libgdal.so with a newer ogrinfo).
Please review your shared library path settings.  You may want to remove
an older libgdal.so, or perhaps set LD_LIBRARY_PATH to ensure the newer
library version gets picked up.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
