[Gdal-dev] GDAL and Solaris 10/sparc
Shaun Kolomeitz shaun.kolomeitz at epa.qld.gov.au
Tue Aug 22 21:23:51 EDT 2006
After months of searching, hacking and many hundreds of compile attempts I am still unable to successfully get GDAL to compile on a SPARC/Solaris 10 environment. No amount of searching lists and getting obscure possible fixes has worked.
My original aim was to get GDAL with ECW compiled and going, but for now I'd even settle for just Geotiff, HFA and JPEG. I'll just have to use WindoZe to do any other conversions.
Would someone mind sending me some settings from their working GDAL sparc/Solaris X configurations ?
Stuff like the system wide "crle", PATH and LD_LIBRARY_PATH settings for compilation and the versions of GCC/etc that actually work.
Any other suggestions that might help me get this going would be most welcome.
TIA,
Shaun
___________________________
Disclaimer
This e-mail, including attachments if any, has originated from a Queensland government agency and may contain information that is confidential, or covered by legal professional privilege, and is intended for the named recipient(s) only.  If you have received this message in error, you are asked to inform the sender as quickly as possible and delete this message and any copies of this message from your computer system network.
Any form of disclosure, modification, distribution and/or publication of this e-mail, including attachments is prohibited.  Unless otherwise stated, this e-mail, including attachments represents the views of the sender and not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses, the Environmental Protection Agency provides no warranty that all possible viruses have been detected and cleaned.  Any use of this e-mail could harm your computer system.
