[Gdal-dev] Re: [Shapelib] shapelib.dll in a Pocket PC
Mateusz Loskot mateusz at loskot.net
Thu Aug 24 16:10:34 EDT 2006
I'm sorry for this post, I missed the address.
It should reach the shapelib list.
Cheers
Mat
Mateusz Loskot wrote:
> Daniel de la Cuesta wrote:
>> First of all, thank you for your response. I have done what you say and
>> I have added the sources of http://mateusz.loskot.net/tmp/shapelibce.zip
>> to my dll Project but when I build the solution i get the following error:
>> fatal error C1010: unexpected end of file while looking for precompiled
>> header. Did you forget to add '#include "stdafx.h"' to your source?
> Daniel.
> I suppose you created DLL project with precompiled headers support.
> Go to project properties dialog box and next to precompiled headers
> select to not to use precompiled headers in the DLL project.
>> I am using VS 2005. Maybe it doesn´t support C code.
> VS  = Visual Studio but this si a bunch of compilers: C#, VB, VC++, etc.
> So, I'm not sure I understand the problem here.
>> Do I have to use a
>> previous version os VS to generate de .dll for Pocket Pc?
> You need to use Visual C++ compiler in version 6.0 or any above,
> 7.0, 7.1 or 8.0
> Cheers
Mateusz Loskot
