[Gdal-dev] VSI file open/close issue
Fri Aug 25 09:50:07 EDT 2006
Frederic Claudel wrote:
> When using VSI* or VSI*L functions, it seems impossible to mix both, which
> means opening a file using VSIFOpen then closing it with VSIFCloseL.
> Hence my question : how can I tell them apart ? In a new GDAL driver where I
> need to open lots of datasets, I'd like to re-use the opened file descriptor
> included in GDALOpenInfo to avoid unnecessary IO.
> But that file descriptor can be opened by either of VSIFOpen or VSIFOpenL
> (when VSIFOpen fails) - by the way it's always closed using VSIFClose
> Should I use a RTTI function to guess the actual type?
Frederic,
Currently there is no way to distinguish VSI* from VSI*L handles.
However, the "fp" in the GDALOpenInfo is always a VSI* handle.  Drivers
that use VSI*L handes ignore the fp in the GDALOpenInfo and re-open the
file.  Files that don't successfully open with VSIFOpen() (ie. large files
on some systems) are opened with VSIFOpenL(), the header read, and then are
closed again.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
