[Gdal-dev] OGR to access s57 file
Mon Aug 28 18:22:39 EDT 2006
kiruba nantham wrote:
> Dear sir,
>         i am trying to make one ENC file reader using c++ language. i
> just want to know how to diffentiate objects are in the ENC file using
> OGR library?  for example there are many wreaks in the ENC file how to
> sepate them as a ship wreak, dangerous wreak etc.. which OGR funtions i
> should use?  if it is possible please give some example program.
Kiruba,
My suggestion is that you review the S-57 documentation carefully to see
if there are attributes that allow you to meaningfully differentiate
different kinds of wrecks.  Once you know how it is indicated in the S-57
data model it shouldn't be too hard to get the information out of OGR.
When I dump the WRECKS layer in an S-57 dataset the features look like:
OGRFeature(WRECKS):2163
   RCID (Integer) = 2164
   PRIM (Integer) = 1
   GRUP (Integer) = 2
   OBJL (Integer) = 159
   RVER (Integer) = 1
   AGEN (Integer) = 540
   FIDN (Integer) = 2135161787
   FIDS (Integer) = 688
   LNAM (String) = 021C7F43FBBB02B0
   LNAM_REFS (StringList) = (null)
   FFPT_RIND (IntegerList) = (null)
   CATWRK (Integer) = 1
   CONRAD (Integer) = (null)
   CONVIS (Integer) = (null)
   EXPSOU (Integer) = (null)
   HEIGHT (Real) = (null)
   NOBJNM (String) = (null)
   OBJNAM (String) = (null)
   QUASOU (String) = 2
   SOUACC (Real) = (null)
   STATUS (String) = (null)
   TECSOU (String) = (null)
   VALSOU (Real) = (null)
   VERACC (Real) = (null)
   VERDAT (Integer) = (null)
   VERLEN (Real) = (null)
   WATLEV (Integer) = 3
   INFORM (String) = (null)
   NINFOM (String) = (null)
   NTXTDS (String) = (null)
   SCAMAX (Integer) = (null)
   SCAMIN (Integer) = (null)
   TXTDSC (String) = (null)
   RECDAT (String) = (null)
   RECIND (String) = (null)
   SORDAT (String) = (null)
   SORIND (String) = (null)
   POINT (61.1031909 -32.4450159)
Hmm, looking in the gdal/data/s57expectedinput.csv file I see that
the CATWRK field can have the following values:
71,1,non-dangerous wreck
71,2,dangerous wreck
71,3,distributed remains of wreck
71,4,wreck showing mast/masts
71,5,wreck showing any portion of hull or superstructure
So, I think what you need to do is fetch the CATWRK feature attribute
from WRECKS, and compare the value to the range above (1-5).   So
looking at the s57expectedinput.csv file will help you identify what
integer values for some fields correspond with what textual strings.
But generally speaking the best reference is the S-57 specification.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
