[Gdal-dev] Motion: 1.4.0 Beta Release
Daniel Morissette dmorissette at mapgears.com
Fri Dec 1 13:27:07 EST 2006
Howard Butler wrote:
> I move to release 1.4.0 beta 1 of GDAL on Monday, Dec 4th at 18:00 UTC.
+1
FYI I have upgraded the ogrsf_frmts/mitab files to MITAB 1.5.1 a few
minutes ago. This is the last stable release of MITAB. If anyone is
interested, the revision history of MITAB is at
http://mitab.maptools.org/HISTORY.TXT
Also, for those interested in the TAB format, a new release of MITAB
(1.6.0?) should be available soon, and the main feature in this release
is improved spatial index generation code that produces a proper R-Tree
and gives search performance comparable to TAB files generated by
MapInfo. Full details in MITAB bug 1585:
http://bugzilla.maptools.org/show_bug.cgi?id=1585
I didn't want to upgrade OGR to that version yet because some more
testing and a bit of performance tuning when writing files is still
required, but that should make it in the next release of GDAL. If you
can't wait then you can always grab the latest MITAB source from CVS:
same CVS server as GDAL, but checkout project 'mitab'.
Daniel
Daniel Morissette
http://www.mapgears.com/
