[Gdal-dev] Debug assertion failed in GDAL/OGR-1.3.2
Craig Miller craig.miller at spatialminds.com
Fri Dec 1 13:37:41 EST 2006
Jean,
I haven't been following this thread at all, but there are a couple of
common problems that occur when compiling gdal against xerces so I'll just
throw some questions out there in the hopes that it helps you solve your
problem.
When compiling gdal, is wchar_t being used as a built in type?
Project -> Properties -> C++ -> Language -> Treat wchar_t as a built in Type
should be set to "No"
Are you linking against the appropriate debug/release version of xerces when
building?
Are you copying the xerces dll to your project along with the gdal dll?
--Craig
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
> Mateusz Loskot
> Sent: Friday, December 01, 2006 9:46 AM
> To: gdal
> Subject: Re: [Gdal-dev] Debug assertion failed in GDAL/OGR-1.3.2
> Jean-Daniel GONON wrote:
> > Mateusz,
> > GDAL/OGR is a project that I manage only with Visual C++ 2003.
> Jean,
> I'm sorry, but the statement "GDAL/OGR is a project that I
> manage only with Visual C++ 2003." is too general.
> "Visual C++ 2003" is a name of compiler but also a name of
> the whole IDE. So, it's important to precise how you compile
> GDAL, using Visual C++ compiler from command line or from the IDE.
> There are *no* official project files to compile GDAL with
> Visual C++ from  the IDE. IOW, there are no *.sln and *.vcproj files.
> The *only* official way to compile GDAL using Visual C++
> compiler is to use NMAKE program and provided makefile.vc files.
> > I don't use makefile.vc, nor nmake.opt.
> So, how do you build GDAL?
> Have you created your own DLL project file to compile GDAL?
> > But I use command lines only to test "gdal.dll" with
> ogrinfo.exe (that
> > is why I call vsvars32.bat).
> Hmm, you should *not* need to run vsvars32.bat to use GDAL
> library and command line utilities, like ogrinfo.exe.
> I don't understand why you run this script.
> > I think I use in my VC++ project files same options as specified in
> > nmake.opt from www.gdal.ogr.
> > But I am not sure for all flags (you can see in attachement
> file, if
> > you
> > want)
> Ah, now I understand you use your own project files for Visual C++.
> That's the info I was asking for :-)
> I don't see anything suspicious in your project file, all
> flags looks good.
> Unfortunately, I don't have any solution for the problem :-(
> I'd suggest you to compile your GDAL version without Xerces
> support, without linking with Xerces and see if it will help.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
