[Gdal-dev] (no subject)
Alan alankeown at southernphone.com.au
Sun Dec 3 21:46:51 EST 2006
Thanks again Howard,
The answer is:
"Open a "Visual Studio Command Prompt". A shortcut to do that was also
installed with Visual Studio."
I'm back on track now.
Cheers
PS Sorry about the personal reply...
-----Original Message-----
Sent: Monday, 4 December 2006 1:25 PM
To: Alan
Subject: Re: [Gdal-dev] (no subject)
if you have both installed, it is probably some combination of
running vcvars.bat for the right compiler and maybe some PATH
hacking.  I've never had both installed at the same time and don't
know how they interact with each other though.
On Dec 3, 2006, at 7:38 PM, Alan wrote:
> Thanks Howard,
> Now that I've exposed my total lack of expertise:
>  How do make the MSVC 2003 nmake run instead of the MSVC 6 nmake ?
> Cheers
> AlanK
> From: Howard Butler [mailto:hobu at iastate.edu]
> Sent: Monday, 4 December 2006 12:18 PM
> To: Alan
> Cc: gdal-dev at lists.maptools.org
> C# and .NET require MSVC 2003.  It appears as though you are using
> MSVC6.
> Howard
> On Dec 3, 2006, at 7:02 PM, Alan wrote:
>> Following the advice in http://www.nabble.com/forum/ViewPost.jtp?
>> post=7196645&framed=y
>> I completed  " nmake -f makefile.vc interface"  successfully,
>> but "nmake -f makefile.vc"
>> gives the following error:
>> C:\CVSCheckout\GDAL\SWIGC#\swig\csharp>nmake -f makefile.vc
>> Microsoft (R) Program Maintenance Utility   Version 6.00.9782.0
>> Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
>>         sn -k gdal.snk
>> 'sn' is not recognized as an internal or external command,
>> operable program or batch file.
>> NMAKE : fatal error U1077: 'sn' : return code '0x1'
>> Stop.
>> Could someone please suggest what I'm missing?
>> Thanks
>> AlanK
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
