[Gdal-dev] RFC 9: ATL Based COM Interface
Mateusz Loskot mateusz at loskot.net
Mon Dec 4 12:03:35 EST 2006
Frank Warmerdam wrote:
> ivan at ilucena.net wrote:
>> Folks,
>> This message is about a RFC proposal that I have prepared and placed at
>> http://www.gdal.org/rfc9_com.html.
> Ivan,
> Some things I think that should be clarified in the RFC:
Ivan, Frank,
I hope you don't mind I'll join this discussion and share some comments:
>  3) What build environments will be supported? Only visual studio?  If so,
>     what versions?
ATL is usable only with Visual C++ compiler.
It is not possible to build ATL-based stuff with GCC (MinGW) or any
other compilers.
> My understanding is that the C# bindings are accessable from any .net
> language.
I believe so too.
> So it seems that the COM interfaces will mainly be of interest to Delphi
> developers - is that right?
There is also possible target client in Web components like ActiveX
controls for Web. Also Visual Basic 6 could use it.
Certainly, .NET and native C/C++ coders can be COM clients as well.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
