[Gdal-dev] Any possibility of static compile?
Mon Dec 4 12:46:00 EST 2006
Curt Mills wrote:
> I need to do a static compile of my app.  I've been able to compile
> Shapelib, proj, geotiff, and a few other libraries statically so
> far.
> I'd like to get GDAL compiled in, of which we use some of the OGR
> functions, but I recall reading earlier about some problems with
> static compiles of GDAL.  Is there a way to get OGR or the full
> GDAL/OGR library compiled statically these days?
> There's also a way under Linux Standard Base rules to distribute a
> shared library along with the application, so that's my backup plan.
> I'd much rather distribute the entire thing statically linked if
> possible though.  Any hope?
Curt,
John pointed out some of the issues.  For what it is worth, I was able
to issue the following command against my local GDAL build:
  gcc -Ibld/include gdal/apps/gdalinfo.c gdal/libgdal.a -L/usr/local/lib -lgeos
-lgeos_c -L/usr/local/lib -lxerces-c -lpthread -lNCSEcw -lNCSCnet -lNCSUtil
-L/home/warmerda/pkg/HDF4.2r1/NewHDF/lib -lmfhdf -ldf -ljpeg -ltiff -lpng -lpq
-L/usr/lib/postgresql/8.0/lib -lpq -lz -lpthread -lm -lrt -ldl
-L/home/warmerda/pkg/kakadu-5.1/lib -lkdu -lsqlite3 -L/usr/lib -lcurl -lidn
-lssl -lcrypto -ldl -lssl -lcrypto -ldl -lz -L/usr/lib -lmysqlclient -lz
-lcrypt -lnsl -lm -o gdalinfo
This produced a gdalinfo executable with GDAL statically linked in, though
the various support libraries were still .so's.  I did this by configuring
GDAL "--without-libtool" and then linking against gdal/libgdal.a.  Essentially
I took the build's "gdal-config --libs" output replaced the part about -lgdal
itself with the path to libgdal.a, and used the rest unchanged.
So, one data point says static builds are doable.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
