[Gdal-dev] Build csharp swig (from real newbie)
Alan alankeown at southernphone.com.au
Mon Dec 4 17:43:26 EST 2006
Thanks Tamas.
I am, honestly, only partly aware of what I am doing which could explain why
odd things are happening... But all credit to you and the other developers
it appears to work even with my stumbling.
Cheers
AlanK
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Tuesday, 5 December 2006 8:57 AM
To: Alan
Cc: Howard Butler; Gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Build csharp swig (from real newbie)
2006/12/4, Tamas Szekeres <szekerest at gmail.com>:
> 2006/12/4, Alan <alankeown at southernphone.com.au>:
> > Howard & Tamas,
> > I changed the line
> >     link /dll /debug $(OGR_INCLUDE) $(BASE_INCLUDE) ogr_wrap.obj \
> >                 $(EXTERNAL_LIBS) ..\..\gdal.lib\
> >                  /out:gdal_ogr_wrap.dll $(LINKER_FLAGS)
> > To
> >                 $(EXTERNAL_LIBS) ..\..\gdal_i.lib\
> > In swig/csharp/makefile.vc and nmake ran without error.
> I've just changed the necessary files in the CVS for supporting the
> dynamic linking to the gdal dll. You should use the csharp.opt to set
> up the desired meth
Arrgh. Google has accidentally sent my partially written email.
So continuing this letter, you might want to comment out
CSHARP_STATIC_LINKAGE = YES
so as to use the linkage you have set previously.
However I would favour the static linkage, and it seems to be an odd
behaviour you have encountered. Both of the methods are working for me
pretty well.
Maybe you have to fully recompile the core gdal to make it work.
Best Regards,
Tamas
