[Gdal-dev] Needs help for reprojecting a shapefile with ogr2ogr
Jean-Claude Repetto jean-claude.repetto at worldonline.fr
Fri Dec 8 10:47:32 EST 2006
Hello,
I have downloaded a shapefile of France (freely available from the IGN
website at
<http://www.ign.fr/telechargement/MPro/produit/GEOFLA_Dep/GEOFLA-dep-L2-SF.ZIP>
The shapefile contains data in tangent Lambert Conic Conformal
projection, but I need geographical coordinates (longitudes, latitudes).
I am trying to convert the shapefile with ogr2ogr, but the result is wrong.
Since the projection and CS informations are not included in the
original files, I have used the s_srs option to specify them (the
tangent Lambert Conic Conformal projection (lcc1) and the NTF system).
ogr2ogr -f "ESRI Shapefile" -s_srs "+proj=lcc +no_defs +lat_1=46.8
+lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=2200000 +ellps=clrk80
+pm=paris"  -t_srs "+proj=longlat +nodefs +datum=WGS84
+towgs84=168,60,-320" wgs dep_france_dom.shp
The coordinates of the first point of the original file are :
X=801150 Y=2092615
The result of the ogr2ogr command gives :
long = 6.468923293704749,   lat = -0.979340169729739, which is obviously
wrong.
cs2cs gives the correct result :
echo "801150 2092615" | cs2cs -f "%15.10f" +proj=lcc +no_defs
+lat_1=46.8000 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=2200000
+ellps=clrk80 +pm=paris +to +proj=longlat +datum=WGS84 +towgs84=168,60,-320
    4.9245201351   45.8040401819   41.9436330358
Am I doing something wrong, or is there a bug in GDAL 1.3.2 ?
For more information about the projection parameters, you can look at :
<http://www.remotesensing.org/geotiff/proj_list/lambert_conic_conformal_1sp.html>
and <http://www.ign.fr/telechargement/MPro/geodesie/CIRCE/transfo.pdf>,
page 12.
Thanks for your help,
Jean-Claude
