[Gdal-dev] ogr2ogr Default Output SRS
Sun Dec 10 00:24:34 EST 2006
Martin Spott wrote:
> Hi Frank, thanks for responding,
> Frank Warmerdam wrote:
>> There are some "sensitivities" in how ogr2ogr identifies which SRID to use
>> in postgis.  If it doesn't find a match then it creates a new SRID at the
>> "top" of the table, which I suspect did for the 32767 case.
>> It may be that the spatial_ref_sys tables in your different versions of
>> postgis are slightly different in the formatting of the WKT entries and
>> this is in one SRID 4326 gets used and in the other it doesn't.
> But what can a user actually do about this, whose "fault" is it if
> 'ogr2ogr' and PostGIS don't place together nicely, and, which I
> consider even more important, which route to take to solve this issue ?
Martin,
Normally there is no great harm in creating a new SRID for what is a
slightly different formatting of a coordinate system that from a
meaningful point of view matches an existing SRID.
However, the solution, I think would be for OGR to:
  o Do the search based on the proj.4 string rather than the WKT.
    The proj.4 strings are less likely to suffer from formatting
    variations over time.
  o Provide a mechanism (a layer creation option for instance) so
    that the user can force use of a particular SRID whether OGR
    thinks the coordinate systems match or not.
> Apparently PostGIS started shipping newer versions of the
> spatial_ref_sys table with 1.1.6 and 'ogr2ogr' somehow doesn't 'agree'
> with the contents of this table.
> I just ran a test with PostGIS-1.2.0 - same effect as with 1.1.6, still
> using the respective spatial_ref_sys that comes with the very PostGIS
> release. I then pushed the contents of the spatial_ref_sys table from
> PostGIS-1.1.5 into the DB, still running PostGIS-1.2.0, and everything
> is fine. So, is this sort of a bug in 'ogr2ogr' that shows some
> incapability to handle newer EPSG declarations or is this to be
> considered as a misfeature in the recent EPSG files that breaks
> 'ogr2ogr' ?
Note that the spatial_ref_sys for PostGIS is generated with OGR.  So
there is no reason to believe the newer spatial_ref_sys will differ
from what newer OGR versions expect.  Upgrading GDAL/OGR may therefore
help.
Generally speaking comparing coordinate systems is *hard*.  Especially if
you wish to do so efficiently.
If you file a bug against OGR with the two earlier suggestions, I'll try
and have them implemented at some point.  Ideally in time for the GDAL
1.4.0 release.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
