[Gdal-dev] date fields truncated using ogr2ogr to load shpfile into psql
John Cartwright John.C.Cartwright at noaa.gov
Mon Dec 11 13:11:01 EST 2006
Thanks for your reply Howard. I'm using gdal/ogr version 1.3.2, so I
guess that a bug report is in order. I'll try to get a small test case
together today and file the bug report.
-- john
Howard Butler wrote:
> Sorry, I misread the post. This is very likely a bug. Which version of
> GDAL are you using? I recall there being some date work in the PG
> driver after the 1.3.2 release. If you are using a recent version, can
> you file a bug and zip up a shapefile with a couple of offending
> features?
> Howard
