[Gdal-dev] Building GDAL with GEOS in Unix
Elavazhagan M elavazhagan.mouniandy at kcubeconsulting.com
Sat Dec 16 08:03:47 EST 2006
Thanks a lot Mateusz!!!
There was some problem with my operating system. When I freashly installed 'Fedora Core 5' it worked fine for me.
Regards,
Ela.
Mateusz Loskot <mateusz at loskot.net> wrote: Elavazhagan.M wrote:
> Can anyone please guide me how to enable GEOS Support in GDAL (Unix)? I
> have installed Geos 3.0.0rc2 in my system and configured GDAL 1.32 with
> the following commands:
> “./configure –with-geos=yes”. This did not work so I tried with
> “./configure  --with-geos=/root/usr/bin/geos-config” also.
> Although these commands worked well and I successfully installed GDAL,
> when I run the command “ogr2ogr”, it gives the following error message:
> “ERROR 6: Geos support not enabled”
Could you check if the configuration summary printed after ./configure
does finish its job, includes GEOS support enabled (marked with yes)?
> Do I need to change anything in the makefiles of GDAL?
No, you should not need to hack any makefiles.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061216/91809829/attachment.html
