[Fwd: Re: [Gdal-dev] ogrinfo output lists no features on a postgis layer created as a copy using "create table as"]
Dolf Andringa dolf.andringa at elcyion.nl
Sun Dec 17 06:11:18 EST 2006
Well, I've found out what the problem was thanks to Frank and Juergen
Fischer (via irc)...
The problem was that the schema name contains a  -. In postgres that is
not a problem when you put the schema name in double quotes. ogrinfo
places only the tablename in double quotes, not the schema name. That is
what is going wrong......
Should I commit this as a bug report?
Thanks for your help Frank!
Dolf.
Dolf Andringa schreef:
> Ok, Frank helped me a lot!
> I found the difference between the two ogrinfo calls on the two tables.
> The table which does not seem to contain any features show the following
> output when I turn on CPL_DEBUG:
> INFO: ---------- General Layer Report ----------
> OGR_PG: PQexec(DECLARE countCursor CURSOR for SELECT count(*) FROM
> promedico-acni_ds."lw" )
> OGR_PG: DECLARE countCursor CURSOR for SELECT count(*) FROM
> promedico-acni_ds."lw" ; failed.
> OGR_PG: Unable to get extent by PostGIS. Using standard OGRLayer method.
> OGR_PG: PQexec(DECLARE OGRPGLayerReader CURSOR for SELECT "ogc_fid",
> AsEWKT("wkb_geometry"), "adresnr", "huislt", "huisnr", "postk_a",
> "postk_n", "straat", "toev", "x_coord", "y_coord" FROM
> The table which does seem to contain features shows just the following
> General Layer Report:
> acni_bnd."ACNi_shp" )
> So I guess it is a problem with (my) PostGIS (setup). Any ideas? Thanks
> for your help!
> Dolf.
> -------- Originele bericht --------
> Onderwerp: Re: [Gdal-dev] ogrinfo output lists no features on a postgis
> Datum: Sat, 16 Dec 2006 18:42:24 -0500
> Van: Frank Warmerdam <warmerdam at pobox.com>
> Aan: Dolf Andringa <dolf.andringa at elcyion.nl>
> Referenties: <4584163B.8040908 at elcyion.nl>
> Dolf Andringa wrote:
>> Hello everybody,
>> I have a problem with ogrinfo (gdal-1.3.2) and postgres 8.1.5/postgis
>> 1.1.6 running on debian linux.
>> I have imported a shapefile into postgis using the python ogr module.
>> When I use ogrinfo to get the number of features of this pg table, the
>> correct number of features is shown. All other data is correct as
>> well. Using ogr2ogr to create a shapefile from this pg layer (as a
>> check) gives a correct shapefile again, so the postgres table is ok.
>> Subsequently I do a create table as to make a copy of this table
>> within postgres. I am doing these queries:
>> CREATE TABLE "promedico-acni_ds"."lw" AS SELECT * FROM
>> "acni_bnd"."ACNi_shp"
>> INSERT INTO public.geometry_columns
>> (f_table_catalog,f_table_schema,f_table_name,f_geometry_column,coord_dimension,srid,type)
>> VALUES ('','promedico-acni_ds','lw','wkb_geometry',2,-1,'POINT')
> Dolf,
> I'm sorry but I don't know what is going wrong.  If you file a detailed
> bug report with easy to reproduce steps (hopefully a small dataset for
> instance) then hopefully we can dig into this before the 1.4.0 release
> is finalized.
> I would also note that you can see most of the SQL queries that OGR
> is issuing to postgres if you define the CPL_DEBUG environment variable
> with the value ON.  This might help with diagnosing the problem.
> Best regards,
