[Gdal-dev] gdaladdo -r average tiled.img 2 4 8 16 32 64 128 does not give 100 -done message at the end
Mon Dec 18 20:39:36 EST 2006
John Mitchell wrote:
> Hi,
> I converted a GeoTiff to a Erdas Imagine format by running the below statement:
> gdal_translate -of HFA original.tif tiled.img
> I then build internal overviews to the image file by running:
> My concern is that it counts down from 0... to 90... 3 times but never
> reaches 100 - done.  When I run the same command against the GeoTiff it
> counts once from 0... to 90...100 - done.  I have successfully opened
> both files in OpenEV_FW and they look identical.
John,
This is nothing to worry about, presumably I have been just a bit careless
in the progress reporting somewhere.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
