[Gdal-dev] GDAL_warp output image sizes vary.... Why?
Wed Dec 20 04:55:10 EST 2006
Sampson, David wrote:
> Hey folks
> I am batching the georef of a bunch of images and find GREAT variances
> between input and output file sizes….
> As the input file size is pretty consistent, and the same X,Y points are
> used for GCP's in each image and the outsize option is set for 67%  I
> would expect a consisent drop in file sizes.
> Why is this not the case? Why do the gdal_warp images maintain their
> appropriate file sizes?  And how can I add this condition in?
> Note. Images start off as 32 bit and end off at 16bit (there is a 50%
> drop already).
> I have had cases where the output file is as large as 50 MEGS….
> Why would the output file be larger than the intermediate file?
> Anyone explain this?
Dave,
Can you use the FWTools Shell "tiffinfo" on one of the input files, and one
of the output files?  I suspect the input files are compressed though there
are a few other possible factors.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
