[Gdal-dev] GDAL_warp output image sizes vary.... Why?
Sampson, David dsampson at NRCan.gc.ca
Wed Dec 20 15:26:56 EST 2006
 Frank,
For the time being I am using the -ts option and defining the outpout
file size. Not the cleanest fix but will work for my next release.
If nothing jumps out at you right now, perhaps I might be able to line
up some test images in the new year for you.
Maybe around the same time we can look closer at the gdal_Translate
buggs with the GCP's.
Thanks for the response. At least I'm not missing something obvious.
Cheers
Happy holidays.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: December 20, 2006 13:10
To: Sampson, David
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] GDAL_warp output image sizes vary.... Why?
Sampson, David wrote:
> List,
> Here are some of the results of tiffinfo.
> Sorry about incorrect info. I meant the image starts at 16 bit and
> ends off as 8 bit.
> Here are the appropriate outputs
Dave,
Despite my hopes, there is nothing like compression to explain this.
If you can supply me with an input file, a gdal_translate or gdalwarp
commandline and the output file you get that is noticably larger I can
look into this in more detail.  It is not at all obvious why this should
be happening.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
