[Gdal-dev] gdal1.4.0beta2.tar.gz contains gdal1.4.0beta1 code???
Fri Dec 29 15:32:59 EST 2006
Dori wrote:
> Hi,
> I have already tried to use gdal by downloading FWTools updated with
> beta2 and a problem I experienced with previous gdal version is still
> there(pls. see below description of original problem).  So, I decided to
> try on a different computer with gdal package.
> I downloaded gdal1.4.0beta2.tar.gz package from gdal.org
> <http://gdal.org> yesterday.  I compile the source code and install gdal
> on a Ubuntu Linux PC.  All seemed to be OK.  However, when I tried to
> find out if the proper version was installed by running: "gdalinfo
> --version" , I got version 1.4.0beta1 version installed.
> I didn't install beta1 before in this PC.  Does anyone have an idea if
> this is just a bug and the version is beta2 although the --version says
> is beta1?
Dori,
I accidentally neglected to update the internal version info in Beta2, so
it still reports beta1.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
