[Gdal-dev] ogr_miattrind.cpp dependency
Mateusz Łoskot mateusz at loskot.net
Mon Feb 6 03:11:56 EST 2006
As I revealed ogr\ogrsf_frmts\generic\ogr_miattrind.cpp file
is dedicated to MapInfo and has nothing to do with other drivers.
Am I right?
If I am, then why it seems to be required dependency even if I want to
build only shapefile support.
Generic OGRLayer::InitializeIndexSupport
calls OGRCreateDefaultLayerIndex and the only implementation of
OGRCreateDefaultLayerIndex function is available from ogr_miattrind.cpp
file:
OGRLayerAttrIndex *OGRCreateDefaultLayerIndex()
     return new OGRMILayerAttrIndex();
But as I said, ogr_miattrind.cpp is coupled with MapInfo driver, so
currently there is no way to build OGR with shapefile driver but without
MapInfo driver.
Am I right or I've missed something while analysing OGR sources.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
