[Gdal-dev] ECW File open failed
Mon Feb 6 15:35:38 EST 2006
On 2/6/06, Ken Sewell <sewell at dramail.com> wrote:
> I'm running off of the GDAL CVS (16 Jan) with the ecwsdk-3.2.11Jun2005
> package.  Gdal showed ecw support in the configure step. Both built and
> installed.  When I run gdalinfo on an ecw file I get the following:
> I'm running on SuSE 10.0/64-bit.  Can anyone shed some light on this for me?  Thanks.
Ken,
You might want to verify that "gdalinfo --formats" lists
ECW format.  Also, I believe there is a 3.3 release
candidate available that would be better than the 3.2
version.  Lastly, I have not tried ECW on a 64bit machine
yet.  That might be a step too far in this case. :-)
Best regards,
